News of electronic
Archive : December 2008 year
3.5-inch Display Module based on ARM Cortex-M3 MCU
23.12.2008 - 09:09
Avnet Memec distributes Luminary Micro’s Intelligent Display Module with 3.5” Landscape Display (MDL-IDM-L35). The module offers a complete QVGA touch-screen user interface for control, automation, and instrumentation applications....
DC/DC boost converter with 0.7V input
19.12.2008 - 09:02
Texas Instruments introduced a 2-MHz DC/DC boost converter that operates at 5 µA of quiescent current, while maintaining a high efficiency at light load conditions. The integrated circuit supports an input voltage of 0.7 V to 5.5 V and an...
ADC for automotive radar applications
11.12.2008 - 09:22
Avnet Memec introduces the MAX11043 quad, 16-bit, simultaneous-sampling ADC for sensor applications from Maxim Integrated Products. Designed for continuous-wave (CW) chirp radar systems, this device provides a complete solution for conditioning and...
Ruggedised panel-mount voltmeter
10.12.2008 - 08:41
The ruggedized, daylight readable DMU-30ACV / DCV series of panel mount, digital voltmeters from Murata Power Solutions is for applications in harsh environments. The 85VAC - 264VAC mains, or 110VDC - 300VDC battery powered meters are suitable for...
Combined Analog Switch and Audio Amplifier IC
05.12.2008 - 12:17
By consolidating an analog switch achieving –80dB isolation and a 1.6W class-D amplifier in a single package, the TS4961T from STMicroelectronics simplifies board design. Using this device, designers can implement both functions within a 3 x...
Hot-Plug Switch for 12V Backplane Applications
04.12.2008 - 09:34
Maxim introduces the DS4560, a fully integrated, self-protected, resettable hot-plug switch. This device reduces the number of components required for the safe insertion and removal of systems on 12V powered backplanes. To minimize solution size and...
Ultrasonic transducer for liquid levels
03.12.2008 - 09:25
Siemens Division Industry Automation has added a PVDF (Polyvinylidene Fluoride) nose cone as an option to the non-contacting ST-H ultrasonic level transducer for liquids. This new material type improves the chemical compatibility of the ST-H...
NiMH Charger IC
02.12.2008 - 09:16
Maxim introduces the DS2710, a stand-alone, NiMH charger IC with alkaline-cell detection. The charger IC to incorporate fast-charge control and alkaline-cell detection. Eliminating the need for circuit design or microcontroller programming, this...
RadioRadar.net - datasheet, service manuals, circuits, electronics, components, semiconductor, CAD
