News of electronic
Archive : January 2009 year
TrenchFET Power MOSFET with backside insulation
23.01.2009 - 10:40
Vishay released an TrenchFET power MOSFET in the chipscale Micro Foot package to feature backside insulation. The Si8422DB is optimized for power amplifier, battery, and load switching in portable devices such as cell phones, PDAs, digital cameras,...
High temperature masking tapes for PCB assembly
22.01.2009 - 15:12
3M has announced adhesive tapes designed for high temperature applications. All the tapes can withstand up to 260 degrees centigrade without any impairment. Target applications include protection when soldering during printed circuit board...
Powertrain control MCU features high-speed flash memory
19.01.2009 - 10:34
Renesas Technology Europe announced the SH72531, a 32-bit MCU designed for powertrain control of automobile engines and transmissions. The device features a operation of up to 120 MHz and 1.25 megabytes of on-chip high-speed flash memory.The SH72531...
Dual input charger IC with integrated OVP
16.01.2009 - 10:45
By integrating over-voltage protection (OVP) up to 28V for both inputs, AnalogicTech’s AAT3691 is a dual input battery charger IC designed to meet industry requirements for flexible and reliable battery charging from multiple sources. The...
Surface mount PPS film capacitors
16.01.2009 - 10:37
NIC Components has introduced a family of film chip capacitors that offer stable characteristics over a wide operating temperature range. The NSMX series of wound, metalized Polyphenylene Sulfide (PPS) film capacitors is dedicated for use in...
1.6MHz synchronous boost regulator with programmable input current limit
09.01.2009 - 09:54
Linear Technology announces the LTC3125, a 1.6MHz, current mode, synchronous boost DC/DC converter with an accurate and programmable average input current limit. Its internal 1.2A switches can deliver output voltages as high as 5.25V from an input...
RadioRadar.net - datasheet, service manuals, circuits, electronics, components, semiconductor, CAD
