EPC23100 100V GaN ePower Stage for Motor Drives
2 months ago
EPC Introduces 100 V GaN ePower Stage for High-Performance Motor Drives
Efficient Power Conversion (EPC) has launched the EPC23100 family of integrated GaN ePower Stages designed for high-performance motor drive applications. The devices combine high-side and low-side GaN FETs, gate drivers, level-shifting circuitry and protection features in a compact package, significantly simplifying design and reducing component count.
EPC23100 GaN ePower Stage
EPC23100 family — 100 V integrated GaN ePower Stage for motor drives
Key Technical Specifications
  • Family members: EPC23100, EPC23106, EPC23110, EPC23111
  • Voltage rating: 100 V
  • Current capability: up to 35 A / 20 A (depending on device)
  • Integration: high-side + low-side GaN FETs, gate drivers and level-shifting circuitry
  • Duty cycle: continuous operation at 100%
  • Protection features:
    • Fast fault shutdown
    • Safe gate control under power-loss conditions
    • Built-in sensing and protection
  • Compact package optimized for high power density
By integrating the complete power stage into a single device, the EPC23100 family reduces board space, lowers switching losses and improves thermal performance compared to discrete GaN implementations.
Target Applications
  • High-performance BLDC and PMSM motor drives
  • Industrial automation and servo systems
  • Robotics and precision motion control
  • Compact high-efficiency motor controllers
The integrated GaN solution helps engineers achieve higher efficiency, better power density and faster time-to-market in next-generation motor drive designs.
Source:  Electronics For You
Other news ...
