https://www.radioradar.net/en/news_of_electronic/silanna_firepower_ics_boost_charge_all_on_one_chip.html
Silanna FirePower ICs Combine Boost Charging and Laser Firing on a Single Chip
Silanna Semiconductor has launched production of its innovative FirePower family - the SL2001 and SL2002 laser-firing system ICs. These devices are designed for LiDAR, time-of-flight (ToF), and rangefinding applications in automotive, industrial, and portable systems.
According to the company, the SL2001 and SL2002 are the smallest and most efficient laser-firing ICs available, integrating resonant capacitor charging and high-current laser diode driving into one compact chip. This eliminates the need for multiple discrete components and separate power stages, reducing board space, design complexity, power losses, and overall system cost.
Silanna FirePower SL2001 and SL2002 laser-firing ICs
FirePower SL2001 and SL2002 - integration of charging and firing functions (Image: Silanna Semiconductor)
SL2001: High-Power Solution for Automotive and Industrial LiDAR
The SL2001 targets automotive-grade LiDAR and high-power ToF systems. Key features include:
This integration can shrink system footprint dramatically - for example, reducing area from ~400 mm² to 80 mm² when paired with a 400-W quad EEL module.
SL2001 application circuit diagram
Application circuit for the SL2001 high-power laser driver (Image: Silanna Semiconductor)
SL2002: Compact, Low-Voltage Driver for Portable Devices
The SL2002 is optimized for battery-powered, handheld LiDAR and rangefinders operating from 2.8 V to 5.5 V supplies. It delivers:
Both ICs support edge-emitting lasers (EELs) and VCSEL arrays, come in tiny wafer-level chip-scale packages, and include evaluation kits for fast prototyping.
SL2002 functional block diagram
Functional block diagram of the compact SL2002 IC (Image: Silanna Semiconductor)
By combining charging, firing, and control in one chip, Silanna’s FirePower series significantly improves efficiency and simplifies next-generation laser-based measurement systems across industries.
