Key phrase (70 chars max): Rohm Surface-Mount MOSFETs with High Power Density
Rohm Semiconductor has introduced a new series of surface-mount MOSFETs designed to deliver higher power density in compact designs. The devices are available in two package types: the ultra-compact DFN8080-5L (8.0 × 8.0 × 0.85 mm) and the TOLL package (11.68 × 9.9 × 2.3 mm).
Rohm new surface-mount MOSFETs in DFN8080-5L and TOLL packages
The new MOSFETs allow designers to achieve higher power output while significantly reducing board space. The compact packages and standard footprints simplify the transition from older designs and accelerate time-to-market.
With 32 variants and two compact package options, the series provides engineers with flexible choices to optimize performance, size, and cost in modern power electronics designs.
Source: Electronics For You
