https://www.radioradar.net/en/news_of_electronic/schurter_ta35.html
Blue circuit breakers
Schurter’s TA35 series introduces a new generation of Circuit Breakers for Equip-ment. The breakers are available in 1-, 2- or 3-pole arrangements. The rocker-actuating switch can be supplied either with or without illumination, in several colors and with various legends or customer specific symbols. New is the version in fluorescent popular blue. The breakers have been de-signed for efficient snap-in mounting, fitting panel thicknesses ranging from 1 to 4 mm. Connections are made with 6.3 x 0.8 mm quick connect terminals. The TA35 pro-vides both the function of a switch as well as thermal overload protection. It has finely graduated rated currents of 0.05 A to 20 A for the 1- and 2-pole types, or 0.05 A to 12 A for 3-pole versions. An optional protective cover gives a protection class of IP 65, making the unit suitable for applica-tions exposed to dust or splashing water.
 Typical applications are laboratory equip-ment for chemical and medical applica-tions, wood and masonry processing ma-chines, construction site equipment, power generators, cleaning equipment, food-processing equipment and appliances. The circuit breaker is approved according to IEC 60934, UL 1077 and CSA C22.2 235 and carries VDE and cURus.
Source: www.channel-e.biz
