https://www.radioradar.net/en/news_of_electronic/maxim_ds2710.html
NiMH Charger IC
Maxim introduces the DS2710, a stand-alone, NiMH charger IC with alkaline-cell detection. The charger IC to incorporate fast-charge control and alkaline-cell detection. Eliminating the need for circuit design or microcontroller programming, this device offers a single-chip charger solution that protects against system damage due to corrosive cell leakage. The DS2710 thus makes it easy to add in-system NiMH charging to end equipment powered by AA or AAA batteries. Usefull for charging batteries from a USB port, the DS2710 is suited for MP3 players, voice recorders, handheld games, toys, or any other application capable of using standard-size alkaline or NiMH batteries.
 The DS2710's charge-control output regulates charge current using a switch-mode or linear control scheme, enabling application designers to choose between maximizing charge rate and minimizing solution cost and size. The device offers charge control for fast-charging NiMH cells, including precharge conditioning, negative-delta-V fast-charge termination, and top-off charging. Voltage, temperature, and charge-timer monitoring during all charge phases provides redundant secondary charge-termination methods for additional protection against overcharge. Additionally, a status pin drives an LED to indicate precharge, fast-charge, or fault conditions.
 The DS2710 is available in a space-saving, 3mm x 4mm, 10-pin TQFN package. Prices start at $1.52 (1000-up, FOB USA). Samples are available now.
Source: www.channel-e.biz
