Diodes Incorporated has introduced the AL8853AQ, a highly integrated multi-phase boost controller designed specifically for high-power automotive LED lighting applications. The device supports up to four phases and uses SPI communication for flexible configuration and real-time monitoring, making it ideal for advanced matrix LED headlights, adaptive driving beam (ADB) systems, and high-brightness exterior lighting.
Diodes AL8853AQ multi-phase SPI boost controller for automotive LED lighting
The AL8853AQ operates over a wide input voltage range of 4.5 V to 65 V and can deliver output voltages up to 100 V. It supports programmable switching frequencies from 50 kHz to 1 MHz, allowing designers to optimize efficiency and EMI performance.
Main advantages include:
Block diagram showing multi-phase boost topology and SPI control
The AL8853AQ is optimized for demanding automotive lighting systems, including:
Thanks to its multi-phase architecture and SPI interface, the controller enables precise current regulation, improved thermal performance, and simplified system design while meeting strict automotive EMC and reliability requirements.
Typical application: multi-phase boost driving matrix LED headlight
The AL8853AQ is available in a compact 4 mm × 4 mm QFN-24 package. It is already in production, with samples and evaluation boards available now.
