Diodes Inc AL8853AQ: Multi-phase SPI boost controller for automotive LED
1 month ago
Diodes Incorporated Releases Multi-Phase SPI Boost Controller for Automotive LED Lighting
Diodes Incorporated has introduced the AL8853AQ, a highly integrated multi-phase boost controller designed specifically for high-power automotive LED lighting applications. The device supports up to four phases and uses SPI communication for flexible configuration and real-time monitoring, making it ideal for advanced matrix LED headlights, adaptive driving beam (ADB) systems, and high-brightness exterior lighting.
Diodes Incorporated AL8853AQ multi-phase boost controller
Diodes AL8853AQ multi-phase SPI boost controller for automotive LED lighting
Key Features and Performance
The AL8853AQ operates over a wide input voltage range of 4.5 V to 65 V and can deliver output voltages up to 100 V. It supports programmable switching frequencies from 50 kHz to 1 MHz, allowing designers to optimize efficiency and EMI performance.
Main advantages include:
  • Multi-phase operation (1 to 4 phases) for higher power and reduced current ripple
  • SPI interface for dynamic configuration, fault reporting, and real-time diagnostics
  • Built-in protection: over-voltage, over-current, over-temperature, and LED short/open detection
  • AEC-Q100 Grade 1 qualification and wide temperature range (-40°C to +150°C)
  • High current accuracy and excellent dimming performance
AL8853AQ block diagram and multi-phase architecture
Block diagram showing multi-phase boost topology and SPI control
Target Applications
The AL8853AQ is optimized for demanding automotive lighting systems, including:
  • Matrix and pixel LED headlights
  • Adaptive Driving Beam (ADB) systems
  • High-power daytime running lights (DRL)
  • Rear combination lamps with high-brightness LEDs
  • Advanced front lighting systems (AFS)
Thanks to its multi-phase architecture and SPI interface, the controller enables precise current regulation, improved thermal performance, and simplified system design while meeting strict automotive EMC and reliability requirements.
AL8853AQ in automotive matrix LED headlight application
Typical application: multi-phase boost driving matrix LED headlight
The AL8853AQ is available in a compact 4 mm × 4 mm QFN-24 package. It is already in production, with samples and evaluation boards available now.
