Archive : 10 April 2026 год
Diodes Incorporated has introduced the AL8853AQ, a highly integrated multi-phase boost controller designed specifically for high-power automotive LED lighting applications. The device supports up to four phases and uses SPI communication for flexible configuration and real-time monitoring, making it ideal for advanced matrix LED headlights, adaptive driving beam (ADB) systems, and high-brightness exterior lighting.
Diodes AL8853AQ multi-phase SPI boost controller for automotive LED lighting
Key Features and Performance
The AL8853AQ operates over a wide input voltage range of 4.5 V to 65 V and can deliver output voltages up to 100 V. It supports programmable switching frequencies from 50 kHz to 1 MHz, allowing designers to optimize efficiency and EMI performance.
Main advantages include:
- Multi-phase operation (1 to 4 phases) for higher power and reduced current ripple
- SPI interface for dynamic configuration, fault reporting, and real-time diagnostics
- Built-in protection: over-voltage, over-current, over-temperature, and LED short/open detection
- AEC-Q100 Grade 1 qualification and wide temperature range (-40°C to +150°C)
- High current accuracy and excellent dimming performance
Block diagram showing multi-phase boost topology and SPI control
Target Applications
The AL8853AQ is optimized for demanding automotive lighting systems, including:
- Matrix and pixel LED headlights
- Adaptive Driving Beam (ADB) systems
- High-power daytime running lights (DRL)
- Rear combination lamps with high-brightness LEDs
- Advanced front lighting systems (AFS)
Thanks to its multi-phase architecture and SPI interface, the controller enables precise current regulation, improved thermal performance, and simplified system design while meeting strict automotive EMC and reliability requirements.
Typical application: multi-phase boost driving matrix LED headlight
The AL8853AQ is available in a compact 4 mm × 4 mm QFN-24 package. It is already in production, with samples and evaluation boards available now.
