Archive : July 2026 год
30.07.2026 - 09:38
Carlo Gavazzi launches DRC61 insulation monitoring device for high-voltage DC fast chargers. Supports up to 1000 V DC, CCS/CHAdeMO, early fault detection and Modbus RTU communication
29.07.2026 - 12:56
Danisense DP12IP — high-precision closed-loop fluxgate current transducer with 10 ppm linearity and up to 18 A range for PCB-mounted power electronics systems
27.07.2026 - 09:55
Littelfuse launches FlatSuppressX TVS diodes (5 kW and 1 kW) with ultra-low clamping voltage for protecting sensitive 48V automotive electronics
20.07.2026 - 10:06
New high-efficiency motor controller for small electric vehicles with FOC control, comprehensive protection, and support for BLDC/PMSM motors
17.07.2026 - 12:51
EVE NET creates a private offline mesh network supporting 200+ devices up to 500m range with 72-hour battery life — perfect for disaster zones and remote areas without any infrastructure.
16.07.2026 - 10:25
New generation of compact high-precision sensors designed for tight industrial spaces, delivering excellent accuracy, fast response, and reliable operation in harsh environments
14.07.2026 - 11:22
New high-precision pressure sensors optimized for EV battery cooling systems, delivering accurate real-time monitoring for improved thermal management and safety
13.07.2026 - 10:23
NOVOSENSE launches NSM101x Hall-effect switch and latch sensors with wide voltage range, high ESD protection and AEC-Q100 qualification for automotive position detection
10.07.2026 - 10:26
New security key enables safe and convenient passwordless login with strong protection against phishing and other threats
09.07.2026 - 09:20
Rohm launches surface-mount MOSFETs in DFN8080-5L and TOLL packages with high power density and 32 variants for power electronics applications
