Danisense DP12IP Current Transducer for Power Electronics
3 months ago
Danisense DP12IP High-Precision Current Transducer for Power Electronics
Danisense has released the DP12IP, a high-precision closed-loop fluxgate current transducer designed for isolated DC and AC current measurement in demanding PCB-mounted power electronics applications. It delivers ppm-class accuracy and excellent long-term stability in a compact form factor.
Danisense DP12IP current transducer
Danisense DP12IP high-precision current transducer for PCB power systems
Key Specifications
  • Technology: Closed-loop compensated fluxgate with second-harmonic zero-flux detection
  • Current range: Up to 18 A (DC and AC)
  • Linearity error: Maximum 10 ppm
  • Accuracy: ppm-class
  • Measurement resistor: Up to 100 Ω at full scale
  • Form factor: 32 mm, weight 250 g
  • Mounting: PCB-mount, suitable for 1U power supplies
  • Fixed excitation frequency for stable performance
The DP12IP provides electrical isolation between the measured circuit and the measurement electronics, making it ideal for high-accuracy monitoring in precision power systems.
Target Applications
  • Precision power supplies and magnet power supplies
  • Battery test benches and battery emulators
  • Servo drives and motion control systems
  • Power analysis and measurement systems
  • Particle accelerator power supplies
With its combination of high precision, compact size, and PCB integration, the DP12IP addresses the growing need for accurate and stable current measurement in next-generation power conversion platforms.
Source: Electronics For You
