Archive : September 2026 год
30.09.2026 - 11:42
Vishay Sfernice D2TO35S is a top-side cooled automotive power resistor in TO-263 package that dissipates up to 35 W and significantly reduces PCB thermal load
29.09.2026 - 09:33
Diodes Field-Plated SBR rectifiers offer ultra-low VF, low reverse leakage and high avalanche capability (up to 145 mJ) for automotive DC-DC converters, battery charging and LED lighting
28.09.2026 - 09:05
Infineon PSOC Control C3 Performance Line MCUs combine high-speed real-time control, wide-bandgap readiness and post-quantum security for AI server PSUs, solar, EV charging and motor drives
24.09.2026 - 15:49
An open-hardware Electrical Testing Board costing about $790 provides automated in-circuit and functional testing with 16 nodes and multi-parameter measurement capabilities
23.09.2026 - 10:12
STMicroelectronics STGI15C60S is a new compact 600V 20A IGBT module that cuts footprint by over 30% while integrating gate drivers, protection and DBC thermal performance for motor drives
21.09.2026 - 09:15
Vicor showcases high-density DC-DC modules for defence platforms that deliver higher power within strict SWaP limits and meet key MIL-STD requirements
17.09.2026 - 09:36
Infineon OPTIREG TLE9744QK is a fully integrated PMIC for EV traction inverters with built-in resolver excitation and ASIL-D safety logic, reducing system complexity and board space.
16.09.2026 - 09:17
TDK launches expanded ultra-compact snap-in capacitors (up to 500 V, 80–2060 µF, 5.39 A ripple) designed for high-power-density AI server PSUs and industrial SMPS
15.09.2026 - 12:52
Compact K78xx-500R3 DC/DC modules deliver regulated positive and negative outputs up to 500 mA with up to 95% efficiency in a tiny SIP-3 package
13.09.2026 - 12:09
ROHM SDR01 Series offers 0.33 W power handling in 0402 size with high surge resistance and thermal stability for compact high-density electronics
