STMicroelectronics STGI15C60S Compact IGBT Module Cuts Footprint for Motor Drives
Table of contents
STMicroelectronics has introduced the STGI15C60S, the first device in its new SLLIMM Compact intelligent power module family. This 600 V, 20 A three-phase IGBT inverter module delivers a significantly smaller footprint while maintaining high thermal performance and comprehensive protection features for motor-drive applications.
STMicroelectronics STGI15C60S compact IGBT module
STMicroelectronics STGI15C60S SLLIMM Compact 600V 20A IGBT module
Key Characteristics
  • Voltage / Current rating: 600 V, 20 A three-phase IGBT inverter
  • Footprint: 18.8 mm × 32.8 mm — more than 30% smaller than comparable DBC packages
  • Substrate: Direct-bonded copper (DBC) for improved thermal performance
  • Package: Fully isolated CDIPB-26L DBC with topside cooling
  • Isolation rating: 2000 Vrms minimum
  • Switching: Hard-switching topologies up to 20 kHz
  • Integrated components:
    • High-side and low-side gate-driver ICs
    • Short-circuit-rugged trench-gate field-stop IGBTs
    • Fast soft-recovery freewheeling diodes
    • Bootstrap diode
  • Protection features:
    • Undervoltage lockout (UVLO)
    • Smart shutdown
    • Temperature sensor
    • Fault comparator
  • High-side reference outputs placed on the signal side to simplify bootstrap circuit design
The compact design and integrated protection functions make the STGI15C60S particularly suitable for space-constrained motor-drive applications while improving thermal management and system reliability.
Target Applications
  • Industrial motor control
  • Air conditioners and heat pumps
  • Washing machines
  • Fans, pumps and compressors
  • Other home appliances and low- to medium-power motor drives
The SLLIMM Compact family is planned to expand with additional current ratings and configurations, offering designers a scalable path to smaller, more efficient power stages.
Source:  Electronics For You
Table of contents
All news of day
