Archive : August 2026 год
31.08.2026 - 09:36
Vishay Dale IFBT series: 17 SMD flyback transformers for PoE and isolated DC/DC converters up to 30 W with 1500 VRMS isolation and flexible windings
26.08.2026 - 09:25
ROHM launches 4th-generation 650V IGBTs featuring 1.55V VCE(sat) and excellent short-circuit robustness for electric vehicle compressors, HV heaters, and industrial inverters
24.08.2026 - 19:03
PwrBlock 323 from Everypin is a compact open-hardware programmable power supply (1–32 V / 3 A) designed for integration into automated test fixtures and HIL systems
20.08.2026 - 11:24
TDK SensEI edgeRX PRO multi-sensor node combines vibration, acoustic, magnetic and temperature sensing with edge AI for more accurate predictive maintenance in industrial environments
19.08.2026 - 09:43
KMM introduces non-contact displacement sensors capable of measuring movement in extreme heat (up to 1200°F) and pressure (up to 5000 psi) for aerospace and nuclear applications
18.08.2026 - 11:33
PI launches the E-413 six-channel low-noise piezo driver with ±250 V bipolar output and up to 100 mA per channel for nanopositioning and multi-axis actuators
17.08.2026 - 08:56
Microchip introduces a low-power NFC bridging reference design on PIC16F13145 with 2.5 mA operation, dual power modes, and mikroBus expansion for fast development of connected devices
12.08.2026 - 09:27
New 150W quarter-brick DC/DC module HLK-150MQ110S24A with wide 43–160 V input and high isolation targets railway power systems under EN50155
11.08.2026 - 08:52
Rigol RSA800 and DINA800 compact RF analysers deliver advanced spectrum and vector network analysis in a portable 1.9 kg package for wireless, EMC and antenna testing
07.08.2026 - 10:52
Nuvoton launches secure silicon solutions for AI cloud and OCP platforms — including compact BMC SiP, Satellite Management Controller with PQC, and high-voltage battery monitoring ICs
