PI E-413: Six-Channel Piezo Driver for Precision Motion Control
2 months ago
PI E-413 Six-Channel Piezo Driver Delivers Precision Control for High-Performance Applications
PI (Physik Instrumente) has introduced the E-413, a compact six-channel piezo driver designed for precise control of piezoelectric devices. The low-noise amplifier supports bipolar high-voltage operation and is optimized for multi-axis piezo systems, including stacks, scanner tubes, shear actuators, and XYZ stages in both static and dynamic applications.
PI E-413 six-channel piezo driver
PI E-413 six-channel piezo driver for transducers, scanner tubes, and actuators
Key Specifications
  • Number of channels: 6 independent high-voltage outputs
  • Output voltage range: –250 V to +250 V (bipolar operation)
  • Peak current: up to 100 mA per channel
  • Peak power: 50 W
  • Noise performance: Low-noise design for high-precision applications
  • Form factor: Compact design with OEM modules available
The multi-channel architecture simplifies control of complex multi-axis piezo devices, tubes, benders, and positioning stages from a single unit, reducing system complexity and space requirements.
Target Applications
  • Nanopositioning and precision stages
  • Scanner tubes and shear actuators
  • Active optics and vibration cancellation
  • Micromachining, micro-pumping, and micro-dispensing
  • Medical engineering, photonics, microscopy, and nanotechnology
  • Aerospace, laser processing, and research systems
Piezoelectric transducers can respond in the microsecond range, enabling fast and accurate motion. The E-413 leverages this capability to support high-speed switching, valve control, and other demanding industrial and research applications.
Source:  Electronics For You
