PI (Physik Instrumente) has introduced the E-413, a compact six-channel piezo driver designed for precise control of piezoelectric devices. The low-noise amplifier supports bipolar high-voltage operation and is optimized for multi-axis piezo systems, including stacks, scanner tubes, shear actuators, and XYZ stages in both static and dynamic applications.
PI E-413 six-channel piezo driver for transducers, scanner tubes, and actuators
The multi-channel architecture simplifies control of complex multi-axis piezo devices, tubes, benders, and positioning stages from a single unit, reducing system complexity and space requirements.
Piezoelectric transducers can respond in the microsecond range, enabling fast and accurate motion. The E-413 leverages this capability to support high-speed switching, valve control, and other demanding industrial and research applications.
Source: Electronics For You
