150W Quarter-Brick DC/DC Module for Railway Applications
2 months ago
HLK-150MQ110S24A 150W DC/DC Module Targets Railway Power Systems
Shenzhen Hi-Link Electronic has introduced the HLK-150MQ110S24A, a compact 150W quarter-brick DC/DC power module designed for railway and transportation systems. Distributed by Rajguru Electronics, the module delivers a regulated 24 V output from a wide 43–160 VDC input and is specified for EN50155 railway applications.
HLK-150MQ110S24A railway DC/DC module
HLK-150MQ110S24A 150W quarter-brick DC/DC module for railway power systems
Key Specifications
  • Input voltage range: 43–160 VDC (4:1), rated 110 VDC
  • Output: 24 VDC / up to 6.25 A (150 W)
  • Efficiency: up to 91% at full load
  • Switching frequency: 250 kHz typical
  • Transient recovery time: 200 µs typical
  • Temperature drift: ±0.02 %/°C maximum
  • MTBF: 150,000 hours
  • Operating temperature: –40°C to +105°C
Isolation & Protection
  • Input-to-output isolation: up to 3000 VDC
  • Input-to-case isolation: 2100 VDC
  • Insulation resistance: ≥ 100 MΩ
  • Output overvoltage protection threshold: 125–140%
  • Protections: input undervoltage, output overcurrent, overvoltage, overtemperature, short-circuit (self-recovering hiccup mode)
Additional functions include remote on/off control, output voltage trimming and remote compensation. No minimum load is required.
Mechanical & Cooling
  • Form factor: quarter-brick
  • Weight: 72 g (standard), 125 g (with radiator)
  • Optional aluminium radiator: 61 × 39 × 15 mm
  • Cooling: conduction or forced-air
Target Applications
  • Railway control electronics and onboard systems
  • Transportation power subsystems requiring stable 24 V
  • Industrial equipment with wide DC bus variation
With its wide input range, high isolation, comprehensive protection and compact size, the HLK-150MQ110S24A is well suited for demanding railway environments where reliability and electrical safety are critical.
Source: Electronics For You
