HLK-150MQ110S24A 150W DC/DC Module Targets Railway Power Systems
Shenzhen Hi-Link Electronic has introduced the HLK-150MQ110S24A, a compact 150W quarter-brick DC/DC power module designed for railway and transportation systems. Distributed by Rajguru Electronics, the module delivers a regulated 24 V output from a wide 43–160 VDC input and is specified for EN50155 railway applications.
HLK-150MQ110S24A 150W quarter-brick DC/DC module for railway power systems
Key Specifications
Input voltage range: 43–160 VDC (4:1), rated 110 VDC
Additional functions include remote on/off control, output voltage trimming and remote compensation. No minimum load is required.
Mechanical & Cooling
Form factor: quarter-brick
Weight: 72 g (standard), 125 g (with radiator)
Optional aluminium radiator: 61 × 39 × 15 mm
Cooling: conduction or forced-air
Target Applications
Railway control electronics and onboard systems
Transportation power subsystems requiring stable 24 V
Industrial equipment with wide DC bus variation
With its wide input range, high isolation, comprehensive protection and compact size, the HLK-150MQ110S24A is well suited for demanding railway environments where reliability and electrical safety are critical.
