Compact K78xx-500R3 DC/DC Modules with Regulated Outputs
1 month ago
Compact K78xx-500R3 DC/DC Modules Deliver Efficient Regulated Power
Rajguru Electronics has introduced the K78xx-500R3 series of non-isolated DC/DC power modules. These compact modules provide regulated positive and negative outputs with high efficiency, short-circuit protection, and a small SIP-3 package, making them ideal for space-constrained industrial, IoT, and embedded applications.
K78xx-500R3 compact DC/DC modules
K78xx-500R3 series compact non-isolated DC/DC power modules
Key Specifications
  • Package: SIP-3 (11.50 × 7.55 × 10.20 mm), weight 1.95 g
  • Output current: up to 500 mA (positive versions), up to 300/150 mA (negative versions)
  • Positive outputs: 3.3 V, 5 V, 9 V, 12 V, 15 V
  • Negative outputs: –5 V, –12 V, –15 V
  • Input voltage: up to 36 V DC (model dependent)
  • Typical efficiency: up to 95%
  • Ripple & noise: as low as 20 mVp-p typical
  • Operating temperature: –40°C to +85°C
  • Transient response deviation: 50 mV typical
  • Temperature drift: ±0.03%/°C
  • Maximum capacitive load: up to 680 µF
  • MTBF: 2,000,000 hours (25°C, MIL-HDBK-217F)
  • Sustainable short-circuit protection with self-recovery
The modules meet CISPR32/EN55032 Class B EMI requirements (with recommended circuit) and offer good immunity to ESD, surge, and conducted disturbances.
Target Applications
  • Industrial control systems
  • IoT devices and embedded controllers
  • Communication equipment
  • Automotive and rail electronics
  • Electric power systems
Thanks to their compact size, high efficiency, and robust protection features, the K78xx-500R3 modules allow designers to implement regulated power conversion without discrete linear regulators, saving board space and simplifying thermal design.
Source:  Electronics For You
