Archive : 15 September 2026 год
Rajguru Electronics has introduced the K78xx-500R3 series of non-isolated DC/DC power modules. These compact modules provide regulated positive and negative outputs with high efficiency, short-circuit protection, and a small SIP-3 package, making them ideal for space-constrained industrial, IoT, and embedded applications.
K78xx-500R3 series compact non-isolated DC/DC power modules
Key Specifications
- Package: SIP-3 (11.50 × 7.55 × 10.20 mm), weight 1.95 g
- Output current: up to 500 mA (positive versions), up to 300/150 mA (negative versions)
- Positive outputs: 3.3 V, 5 V, 9 V, 12 V, 15 V
- Negative outputs: –5 V, –12 V, –15 V
- Input voltage: up to 36 V DC (model dependent)
- Typical efficiency: up to 95%
- Ripple & noise: as low as 20 mVp-p typical
- Operating temperature: –40°C to +85°C
- Transient response deviation: 50 mV typical
- Temperature drift: ±0.03%/°C
- Maximum capacitive load: up to 680 µF
- MTBF: 2,000,000 hours (25°C, MIL-HDBK-217F)
- Sustainable short-circuit protection with self-recovery
The modules meet CISPR32/EN55032 Class B EMI requirements (with recommended circuit) and offer good immunity to ESD, surge, and conducted disturbances.
Target Applications
- Industrial control systems
- IoT devices and embedded controllers
- Communication equipment
- Automotive and rail electronics
- Electric power systems
Thanks to their compact size, high efficiency, and robust protection features, the K78xx-500R3 modules allow designers to implement regulated power conversion without discrete linear regulators, saving board space and simplifying thermal design.
Source: Electronics For You
