TDK Compact Snap-In Capacitors for AI Server PSUs
1 month ago
TDK Expands Compact Snap-In Capacitors for AI Server Power Supplies
TDK Corporation has expanded its ultra-compact snap-in aluminium electrolytic capacitor series (B43645, B43657, B43658, B43659, B43660, and B43661) with rated voltages up to 500 V. These capacitors are designed for high-power density applications in AI server power supply units (PSUs), high-performance switch-mode power supplies (SMPS), UPS systems, and solar inverters.
TDK compact snap-in capacitors for AI servers
TDK B436xx series ultra-compact snap-in aluminium electrolytic capacitors
Key Specifications
  • Rated voltage: up to 500 V DC
  • Capacitance range: 80 µF – 2060 µF
  • Dimensions: diameter 22–35 mm, length 25–100 mm
  • Ripple current: up to 5.39 A
  • Service life: up to 5,000 hours at +105 °C
  • Design: aluminium can with PET sleeve, snap-in terminals, integrated pressure relief vent
  • Versions: 2-terminal (standard) and 3-terminal (for correct polarity insertion)
  • RoHS-compliant and vibration-tested according to IEC 60068-2-6
The compact capacitance-voltage (CV) design allows engineers to fit more capacitance into limited board space, increasing power density without enlarging the capacitor bank footprint. These devices are particularly suitable for continuous high-load operation in AI data centre power supplies.
Target Applications
  • AI server power supply units (PSUs)
  • High-performance switch-mode power supplies (SMPS)
  • Uninterruptible power supplies (UPS)
  • Solar inverters
  • DC-link and energy storage circuits
TDK also provides the web-based AlCap Tool that helps calculate expected capacitor lifetime under specific operating conditions, supporting more accurate and reliable power supply designs.
Source: Electronics For You
