ROHM SDR01: 0.33 W High-Power Resistors in 0402 Package
1 month ago
ROHM SDR01 Series: High-Power Anti-Surge Resistors in 0402 Size
ROHM has launched the SDR01 Series of high anti-surge chip resistors that deliver 0.33 W rated power in the ultra-compact 0402 (1005 Metric) package. The series combines high surge resistance, thermal stability and small size for dense automotive, industrial, consumer and AI server applications.
ROHM SDR01 high-power 0402 resistors
ROHM SDR01 Series high anti-surge chip resistors in 0402 size
Key Specifications
  • Package size: 1.00 × 0.50 × 0.35 mm (0402 / 1005 Metric)
  • Rated power: 0.33 W
  • Rated terminal temperature: 125°C
  • Resistance range: 10 Ω to 2.2 MΩ
  • Tolerance: ±1% (F-class)
  • TCR: ±100 ppm/°C
  • Type: High anti-surge chip resistor
Optimized resistive-element and electrode design allows the SDR01 Series to maintain full 0.33 W power rating up to 125°C terminal temperature. This makes the resistors suitable for high-density mounting and placement near heat-generating components while improving surge and ESD withstand capability compared with conventional 0402 resistors.
Target Applications
  • Automotive electronics (power supply, control and interface circuits)
  • Industrial equipment
  • Consumer electronics
  • AI servers and high-density computing
  • Power supply and peripheral interface circuits
The compact size enables designers to replace larger resistors or reduce the number of components, helping shrink PCB area without sacrificing reliability in surge-prone environments.
Source:  Electronics For You
Other news ...
