https://www.radioradar.net/en/news_of_electronic/danisense_dp12ip_current_transducer_power_electronics.html
Danisense DP12IP High-Precision Current Transducer for Power Electronics
Danisense has released the DP12IP, a high-precision closed-loop fluxgate current transducer designed for isolated DC and AC current measurement in demanding PCB-mounted power electronics applications. It delivers ppm-class accuracy and excellent long-term stability in a compact form factor.
Danisense DP12IP current transducer
Danisense DP12IP high-precision current transducer for PCB power systems
Key Specifications
The DP12IP provides electrical isolation between the measured circuit and the measurement electronics, making it ideal for high-accuracy monitoring in precision power systems.
Target Applications
With its combination of high precision, compact size, and PCB integration, the DP12IP addresses the growing need for accurate and stable current measurement in next-generation power conversion platforms.
Source: Electronics For You
