https://www.radioradar.net/en/news_of_electronic/carlo_gavazzi_drc61_isolation_monitor_dc_fast_charging.html
Carlo Gavazzi DRC61: Smarter Isolation Monitoring for EV Fast Chargers
Carlo Gavazzi has introduced the DRC61 insulation monitoring device designed for unearthed (IT) high-voltage DC systems in Mode 4 DC fast-charging stations. The device continuously monitors insulation resistance between the DC lines and protective earth, enabling early detection of insulation degradation and improving both safety and charger availability.
Carlo Gavazzi DRC61 isolation monitoring device
Carlo Gavazzi DRC61 insulation monitoring device for high-voltage DC charging
Key Specifications and Features
By detecting insulation resistance drop early, the DRC61 allows operators to perform preventive maintenance instead of reacting only after a fault occurs. This reduces downtime and increases the reliability of high-power EV charging stations.
Target Applications
The DRC61 simplifies system design by eliminating external adapters, reduces component count, and helps OEMs optimise space and cost in modern high-power charging infrastructure.
Source: Electronics For You
