Erqos EQSP32 Controller Brings AI-Based Code Testing with Real Hardware-in-the-Loop
Erqos has introduced hardware-verified agentic programming for its EQSP32 Connected MicroPLC. The new capability adds native Hardware-in-the-Loop (HIL) functionality, allowing an AI agent to generate, execute and validate industrial control programs directly on the physical controller.
Erqos EQSP32 – AI-generated control programs tested on real hardware
Key Features
Real-silicon execution during automated verification
Deterministic sensor-state and actuator-state injection
Repeatable testing of safety interlocks
Compressed testing for long-duration control sequences
Persistent test artifacts for regression workflows
Closed verification loop: AI generates → loads → tests → revises code on real hardware
Works with a sub-$200 EQSP32 MicroPLC + USB + AI agent (no expensive test bench required)
The EQSP32 runs the actual control program on its own silicon while the AI agent injects simulated sensor conditions and observes the outputs through a serial connection. This creates an independent hardware check instead of relying solely on software simulation.
What It Enables
Safe testing of pressure, temperature, level and switch inputs at precise values
Observation of pumps, valves and alarms under controlled conditions
Injection of fault scenarios (sensor failures, out-of-range values, threshold violations)
Compressed evaluation of long operating sequences, delays and interlocks
In a documented reverse-osmosis water-treatment example, an AI agent generated the functional specification, control program, 31-case HIL test plan, test harness and final report in just 18 minutes of unattended operation — with all 31 tests passing on the real controller.
