Vishay Intertechnology has introduced the XFD11KxxCA series of bidirectional XClampR flat-clamping transient voltage suppressors (TVS). These devices deliver high surge capability with a near-1.0 clamping ratio in a surface-mount DO-218AC package, making them ideal for protecting 12 V, 24 V and 48 V automotive and industrial power systems.
Vishay XFD11KxxCA series bidirectional flat-clamping TVS diodes
The flat-clamping architecture and low dynamic resistance provide lower clamping voltage compared with conventional TVS devices in the same package, while supporting approximately 1.6× higher peak pulse current. This allows designers to use lower-voltage-rated downstream components (MOSFETs, capacitors, etc.), reducing cost and voltage guard bands.
The XFD11KxxCA series protects against transients from inductive load switching and lightning while maintaining stable performance across the full temperature range.
Source: Electronics For You
