https://www.radioradar.net/en/news_of_electronic/keysight_dual_channel_20ghz_signal_generator_2u.html
Keysight Dual-Channel Signal Generator Doubles Testing Capacity in the Same Rack Space
Keysight has introduced a dual-channel analog signal generator that packs two independent 20 GHz sources into a single 2U chassis. The PSG XG7-class instrument enables engineers to run multiple test conditions without adding another instrument or expanding rack space.
Keysight dual-channel analog signal generator
Keysight dual-channel 20 GHz analog signal generator in 2U form factor
Key Characteristics
By combining two high-performance sources in one chassis, the generator effectively doubles signal-testing capacity while preserving signal purity and existing rack configurations.
Target Applications
The instrument allows engineers to create independent test conditions from a single unit, reducing equipment count and rack space while maintaining low noise performance essential for accurate high-frequency measurements.
Source: Electronics For You
