Keysight Dual-Channel 20GHz Signal Generator in 2U Chassis
1 week ago
Keysight Dual-Channel Signal Generator Doubles Testing Capacity in the Same Rack Space
Keysight has introduced a dual-channel analog signal generator that packs two independent 20 GHz sources into a single 2U chassis. The PSG XG7-class instrument enables engineers to run multiple test conditions without adding another instrument or expanding rack space.
Keysight dual-channel analog signal generator
Keysight dual-channel 20 GHz analog signal generator in 2U form factor
Key Characteristics
  • Architecture: Dual independent channels in one instrument
  • Frequency range: Up to 20 GHz per channel
  • Form factor: Compact 2U chassis
  • Phase noise: −135 dBc/Hz at 10 GHz (10 kHz offset)
  • Amplitude modulation noise: −150 dBc/Hz at 10 GHz (10 kHz offset)
  • Broadband noise floor: −166 dBc/Hz at 10 GHz
  • Calibrated output power: up to +22 dBm
  • Architecture: Hybrid design with software-based mode switching
  • Supports Standard Commands for Programmable Instruments (SCPI)
  • Rear-panel connections and settings compatible with previous-generation instruments
By combining two high-performance sources in one chassis, the generator effectively doubles signal-testing capacity while preserving signal purity and existing rack configurations.
Target Applications
  • Aerospace and defence testing
  • Advanced wireless systems
  • High-speed digital test environments
  • Complex multi-signal test setups requiring high signal integrity
The instrument allows engineers to create independent test conditions from a single unit, reducing equipment count and rack space while maintaining low noise performance essential for accurate high-frequency measurements.
Source: Electronics For You
