SV Microwave SMPM Mini-D 8-Channel RF Interconnect up to 40 GHz
1 week ago
SV Microwave SMPM Mini-D Compact RF Interconnect Supports Eight Channels
SV Microwave has introduced the SMPM Mini-D RF interconnect system designed for high-density board-to-board applications. The compact interface consolidates eight RF channels into a single space-saving connector, allowing engineers to increase connectivity without consuming multiple individual connector footprints on crowded PCBs.
SV Microwave SMPM Mini-D RF interconnect
SV Microwave SMPM Mini-D eight-port RF interconnect
Key Characteristics
  • Number of channels: 8 RF ports in one compact interface
  • Frequency range: up to 40 GHz
  • Interface type: SMPM RF combined with space-saving D-sub form factor
  • Mating style: Push-on coupling for simplified connection
  • System components:
    • Eight-port ganged RF cable assembly
    • Two PCB connector mating halves
  • PCB mounting options:
    • Surface-mount
    • Edge-launch
  • Compact design optimised for dense RF board layouts
By integrating eight high-frequency channels into a single compact interconnect, the SMPM Mini-D reduces board space requirements, simplifies cable routing and leaves more room for other components in space-constrained systems.
Target Applications
  • Military and aerospace equipment
  • Test and measurement instruments
  • High-density RF modules
  • Board-to-board RF signal transmission in compact systems
Source: Electronics For You
