Vibration Sensors Turn Solar Panels into Rain Gauges — Fraunhofer lokalRAIN Project
Researchers from the Fraunhofer Institute for Digital Media Technology (IDMT) have demonstrated a system that uses structure-borne sound sensors attached to solar panels to estimate rainfall from the vibrations caused by raindrops. The approach turns existing photovoltaic modules into distributed rain gauges without moving parts.
Fraunhofer IDMT lokalRAIN — vibration sensors on solar panels for rainfall measurement
Key Characteristics
Sensing principle: structure-borne sound (vibration) sensors detect raindrop impacts on solar modules
Processing: machine-learning algorithm running on an energy-efficient microcontroller at each sensor node
Only compact processed measurement data is transmitted wirelessly
Accuracy (light rain 2–5 mm/h): mean absolute deviation 1.88 mm/h — meets WMO Class C (max. allowed deviation 2 mm/h)
Wireless range (field trials):
up to 4 km in urban environments
over 35 km in rural line-of-sight conditions
No moving parts → potentially lower maintenance than conventional rain gauges
Data from multiple nodes aggregated centrally for higher-resolution local rainfall maps
Hardware developed by project partner Pan Acoustics
The system is intended to complement rather than replace traditional rain gauges. Current validation covers light rain; performance under heavy rainfall still requires additional training data.
Target Applications
Urban digital twins and municipal control rooms
Flood monitoring and early-warning systems
Support for municipal infrastructure operators and firefighting services
Dense local rainfall measurement networks using existing solar installations
The lokalRAIN project (Oct 2024 – June 2026) produced a working prototype under Germany’s ZIM programme. Further development is needed for sensor housing, electronics and expanded validation under heavy rain and varied environmental conditions.
