Vishay launches 1200V SiC MOSFET power modules in SOT-227 for high efficiency
8 months ago
Vishay Introduces 1200 V SiC MOSFET Power Modules in SOT-227 Packages
Malvern, PA – January 28, 2026 – Vishay Intertechnology, Inc. (NYSE: VSH) announced the launch of five new 1200 V silicon carbide (SiC) MOSFET power modules designed to boost power efficiency in medium- to high-frequency applications across automotive, energy, industrial, and telecom sectors.
Vishay SiC MOSFET module in SOT-227 package]
The new Vishay Semiconductors devices - VS-SF50LA120, VS-SF50SA120, VS-SF100SA120, VS-SF150SA120, and VS-SF200SA120 - feature the company's latest-generation SiC MOSFET technology with integrated soft body diodes. This design significantly reduces reverse recovery losses and enables faster, more efficient switching.
Key Features and Benefits
  • Rated voltage: 1200 V (VDSS)
  • Continuous drain current: 50 A to 200 A
  • Low on-resistance (RDS(on)): down to 12.1 mΩ (for 200 A version)
  • Maximum junction temperature: +175 °C
  • Industry-standard SOT-227 package for drop-in replacement
  • Electrical isolation up to 2500 V for 1 minute
  • Configurations: single-switch or low-side chopper
These modules help minimize conduction and switching losses, reduce heatsink requirements, and support higher operating frequencies - leading to smaller magnetics, simpler cooling, and overall system efficiency gains.
Table of specifications for VS-SF series modules]
Target Applications
The devices are ideal for:
  • DC/DC converters and off-board EV chargers
  • Solar inverters and power systems
  • Switched-mode power supplies (SMPS)
  • UPS systems and HVAC drives
  • Battery energy storage and telecom power units
Available in RoHS-compliant SOT-227 molded packages, the modules serve as easy drop-in replacements for existing designs, eliminating the need for PCB layout changes while upgrading to advanced SiC performance.
SiC power module in application or close-up view]
Samples and production quantities are available now, with lead times of 13 weeks.
