Archive : 9 July 2026 год
09:20Rohm Launches New Surface-Mount MOSFETs for Higher Power Density
Key phrase (70 chars max): Rohm Surface-Mount MOSFETs with High Power Density
Rohm Semiconductor has introduced a new series of surface-mount MOSFETs designed to deliver higher power density in compact designs. The devices are available in two package types: the ultra-compact DFN8080-5L (8.0 × 8.0 × 0.85 mm) and the TOLL package (11.68 × 9.9 × 2.3 mm).
Rohm surface-mount MOSFETs
Rohm new surface-mount MOSFETs in DFN8080-5L and TOLL packages
Key Features
  • Available in DFN8080-5L (8.0 × 8.0 × 0.85 mm) and TOLL (11.68 × 9.9 × 2.3 mm) packages
  • Standard 3V–5V gate threshold for broad driver compatibility
  • Market-standard footprints for easy drop-in replacement
  • Offered in 32 variants for application-specific optimization
  • Extremely low on-resistance for improved efficiency
  • Mass production started in June 2026
The new MOSFETs allow designers to achieve higher power output while significantly reducing board space. The compact packages and standard footprints simplify the transition from older designs and accelerate time-to-market.
Target Applications
  • DC-DC converters
  • Motor control circuits
  • Power supplies
  • Automotive electronics
  • Industrial equipment
With 32 variants and two compact package options, the series provides engineers with flexible choices to optimize performance, size, and cost in modern power electronics designs.
Source: Electronics For You
