AnalogicTech has introduced the AAT1239-1, a constant current boost converter capable of driving up to10 white LEDs (WLEDs) connected in series. Designed for backlight applications in PNDs, eDictionaries, electronic photo frames and cellular handsets, the new driver IC uses AnalogicTech’s proprietary Simple Serial Control (S2CWire) single-wire interface to reduce the display flicker that occurs with commonly-used low frequency PWM control schemes. By driving up to 10 WLEDs in a serial string, the AAT1239-1 simplifies the use of larger LCD panels in a wide array of battery-powered portable devices. Operating off a 2.7V to 5.5V input range, the AAT1239-1 delivers a maximum continuous output of 40V at 30mA and delivers a constant LED current for up to 10 WLEDs in series.
An integrated soft start function eliminates output voltage overshoot across the full input voltage range. The single-wire S2CWire interface controls WLEDs across 26 discrete current steps. It requires no additional circuitry. The AAT1239-1 also features a true load disconnect function that isolates the load from the power source while in the OFF or disabled state. By guaranteeing <1.0 microamps shutdown current, this feature extends battery life by eliminating leakage current in power-limited portable applications. The WLED driver IC offers efficiency levels up to 82%. A 2MHz switching frequency provides fast response. The AAT1239-1 also offers short-circuit, overvoltage and over-temperature protection. Qualified across the -40 C to +85 C temperature range, the AAT1239-1 is available in a Pb-free, 12-pin TSOPJW package.
Source: www.channel-e.biz
