Archive : 4 August 2026 год
Murata Manufacturing has introduced the DE5 series of automotive safety-certified lead-type disc ceramic capacitors. The new series provides higher voltage tolerance, stronger surge protection, and improved electrical isolation for electric vehicle on-board chargers, industrial power systems, and high-voltage AC filtering applications.
Murata DE5 series automotive safety-certified disc ceramic capacitors
Key Specifications
- Safety certification: IEC 60384-14 X1/Y1
- Y1-rated AC voltage: 500 Vac (r.m.s.)
- X1-rated AC voltage: 760 Vac
- DC rated voltage: 1,500 V
- Impulse withstand voltage: 12 kV (increased from 5 kV in previous series)
- Capacitance range: 100 pF to 4,700 pF
- Temperature characteristics: B and E
- Lead spacing: 10 mm (through-hole mounting)
- Package diameter: 6 mm to 14 mm (depending on capacitance)
- Automotive qualification: AEC-Q200 Rev. E
Compared with Murata’s earlier DE6 family (300 Vac Y1 rating), the DE5 series offers significantly higher voltage and impulse withstand capability, giving designers greater safety margins in modern high-voltage EV and industrial systems.
Target Applications
- Electric vehicle on-board chargers (OBC)
- High-voltage AC input filters
- EV charging infrastructure
- Industrial power supplies
- Renewable energy equipment
- EMI suppression circuits requiring reinforced insulation
The DE5 series is designed for applications where conventional Y2-class capacitors no longer provide sufficient safety margin, helping improve reliability and surge immunity in demanding automotive and industrial environments.
Source: Electronics For You
