Archive: 11 November 2026
12:04Olimex UEXT-CH390 Adds Wired Ethernet to Raspberry Pi Pico and ESP32
Olimex has released the UEXT-CH390, a compact module that adds 10/100 Mbps wired Ethernet to development boards that have no network interface of their own. It targets the Raspberry Pi Pico and Pico 2 as well as boards based on the ESP32-S3, ESP32-C3, ESP32-C5 and ESP32-C6. It is a handy alternative to Wi-Fi where a stable link matters: in control cabinets, sensor nodes and smart home devices.
Olimex UEXT-CH390 Ethernet module for Raspberry Pi Pico and ESP32
UEXT-CH390 module. Photo: Olimex
Key specifications
  • Controller: WCH CH390 SPI-to-Ethernet controller with integrated MAC and PHY
  • Speed: 10BASE-T and 100BASE-TX, up to 100 Mbps
  • Host interface: SPI
  • Connectors: standard UEXT plus an additional 1 mm pitch pUEXT
  • Power: 3.3 V through the UEXT or pUEXT connector
  • Other: packet buffer and a pre-programmed MAC address
  • Dimensions: 50 x 21 mm
Unlike the popular W5500, the CH390 has no hardware TCP/IP stack: the network protocols run on the microcontroller itself, for example with the lwIP library. For the RP2040 and ESP32 this is not a problem.
Software support
  • ESPHome and Home Assistant. Olimex has written a CH390 driver for the RP2040 in ESPHome. In the demo on the RP2040-PICO30U-16 board, the module gets its address via DHCP, is discovered automatically by Home Assistant and, after the first USB flashing, can be updated over the air (OTA).
  • Pico SDK. A separate example using lwIP and a small web server for developers who build firmware without ESPHome.
Open hardware and price
The UEXT-CH390 is open-source hardware: the schematic, KiCad board files, firmware and examples are published on GitHub. The module costs 4.95 EUR, or 4.70 EUR each for 10 pieces or more.
Controller documentation is available in the RadioRadar datasheet search.
