Chip Stores Settings Even Without Power
3 months ago
A new type of non-volatile memory chip has been introduced that can retain configuration settings and critical data even when power is completely removed. This innovation eliminates the need for constant power or backup batteries in many applications, significantly improving reliability and reducing power consumption in IoT, industrial, automotive, and consumer electronics.
Non-volatile memory chip that stores settings without power
New chip that retains settings even without power
Key Advantages
  • Zero power consumption in standby mode for stored data
  • Instant-on capability after power restoration
  • High endurance and long data retention
  • Small form factor suitable for space-constrained designs
  • Resistance to power interruptions and brownouts
Traditional solutions often rely on EEPROM, flash memory with backup capacitors, or batteries. The new chip removes these limitations, offering true “set-and-forget” functionality for configuration parameters, calibration data, and system settings.
Target Applications
  • IoT sensors and edge devices
  • Industrial automation and control systems
  • Automotive electronics (ECUs, sensors)
  • Smart home and building automation
  • Medical devices and wearables
This technology is particularly valuable in applications where power supply is unreliable or where ultra-low power operation is essential, enabling more robust and energy-efficient electronic systems.
Source: Electronics For You
