Diodes 32Gbps ReDriver for Automotive Smart Cockpits
5 months ago
Diodes Incorporated Launches 32Gbps ReDriver for Next-Gen Smart Cockpits
Diodes Incorporated has introduced a new automotive-grade four-channel linear ReDriver designed to solve signal integrity issues in advanced smart cockpit platforms. The device supports data rates up to 32 Gbps and is optimized for high-speed interfaces such as PCIe 5.0, SAS4, and CXL, making it ideal for AI-powered cockpits combining ADAS, infotainment, and digital clusters.
Diodes 32Gbps ReDriver for smart cockpits
Diodes four-channel 32Gbps linear ReDriver for automotive smart cockpits
Key Features
  • Supports data rates up to 32 Gbps
  • Four independent differential channels
  • Optimized for PCIe 5.0, SAS4, and CXL protocols
  • Ultra-low jitter thanks to SiGe BiCMOS process
  • Programmable linear equalization and output swing via I2C
  • Ultra-low standby power consumption (< 5 mW)
  • Automotive temperature range: -40°C to +85°C
The ReDriver enables longer PCB traces while maintaining excellent signal quality, helping designers reduce system complexity and component count in next-generation automotive platforms.
Target Applications
  • AI-enabled smart cockpits
  • Digital instrument clusters
  • Advanced Driver Assistance Systems (ADAS)
  • High-resolution infotainment systems
  • GPU + CPU based SoC architectures
The device operates from a 3.3 V supply and supports Modern Standby mode, making it well-suited for power-sensitive automotive designs.
Source: Electronics For You
