Taoglas FXP30x & PC30x: Compact antennas for Cellular + GNSS + Wi-Fi
5 months ago
Taoglas Launches Compact Multi-Connectivity Antennas for IoT and Connected Devices
Taoglas has introduced two new families of embedded antennas — FXP30x (flexible) and PC30x (rigid) — designed to provide multi-standard wireless connectivity in a single compact component. The antennas combine support for cellular, GNSS, and Wi-Fi bands, helping manufacturers simplify designs and reduce size in space-constrained IoT, telematics, wearables, and industrial devices.
Taoglas FXP30x and PC30x multi-connectivity antennas
Taoglas FXP30x and PC30x series compact multi-connectivity antennas
Key Features
  • Wide frequency coverage: 600 MHz to 8000 MHz
  • Supports Cellular (4G/5G), GNSS (GPS, GLONASS, BeiDou, Galileo), and Wi-Fi 6/6E/7
  • Two form factors: ultra-thin flexible FXP30x and rigid FR4 PC30x
  • Pre-assembled with I-PEX MHF I connector and color-coded cables
  • Adhesive mounting for easy integration
  • High efficiency and strong peak gain in small footprints
The flexible FXP30x series is ideal for curved or tight internal spaces, while the rigid PC30x series offers better structural stability for standard enclosures.
Target Applications
  • Asset tracking and telematics
  • Smart agriculture devices
  • e-Mobility and connected vehicles
  • Industrial IoT hardware
  • Connected healthcare and wearables
By integrating multiple wireless technologies into one antenna, Taoglas helps device makers reduce component count, simplify PCB layout, and accelerate product development.
Source: Electronics For You
