Archive : 13 March 2026 год
08:59NXP Launches Industry-First 10BASE-T1S PMD Transceivers for Edge Ethernet
Key phrase (70 chars max): NXP TJA1410/TJF1410: First 10BASE-T1S PMD transceivers for edge
NXP Semiconductors has announced the industry's first production-ready 10BASE-T1S Physical Medium Dependent (PMD) transceivers: TJA1410 for automotive and TJF1410 for industrial/building automation. These devices deliver scalable, low-cost 10 Mb/s single-pair Ethernet (SPE) in multidrop configurations to edge nodes like sensors and actuators.
NXP TJA1410 and TJF1410 PMD transceivers
NXP TJA1410 (automotive) and TJF1410 (industrial) 10BASE-T1S PMD transceivers
Key Features and Architecture
The transceivers split the traditional Ethernet PHY: the digital part resides in an MCU or switch, while the analog front-end PMD handles transmit/receive over a standardized 3-pin OA interface. This reduces pin count, external components, and system complexity while maintaining full IEEE 802.3cg and Open Alliance TC14 compliance.
  • Speed: 10 Mb/s multidrop Ethernet
  • Cable length: Up to 100 m
  • Nodes supported: Up to 32 on a single bus (TJF1410)
  • Package: Compact 3 mm × 3 mm HVSON8
  • Compliance: IEEE 802.3cg, OA TC14 (topology discovery, TC10/TC14 wake-up)
10BASE-T1S PMD architecture block diagram
Block diagram showing split PHY with PMD transceiver
Automotive-Specific Advantages (TJA1410)
  • ISO 26262 ASIL B functional safety compliant
  • AEC-Q100 Grade 1 qualified
  • Supports remote wake-up over data line (no extra wiring)
  • Robust EMC with low-cost CAN FD common-mode chokes
Industrial Advantages (TJF1410)
  • Optimized low quiescent current in power-down mode
  • Power-over-data line compatibility
  • Suitable for zonal/centralized architectures
Multidrop 10BASE-T1S topology example
Multidrop bus topology with up to 32 nodes over single pair
Target Applications
These transceivers enable Ethernet connectivity at the lowest edge levels in software-defined vehicles (SDV), industrial automation, building management, and edge networks-replacing legacy fieldbuses while keeping IP-based communication, security, and scalability.
Already in production, customer integrations are advancing for next-gen platforms requiring cost-effective, unified Ethernet backbones.
