Nuvoton KA85010UA 26-Cell Battery IC with Built-in EIS
2 weeks ago
Nuvoton KA85010UA Battery Monitoring IC Uses EIS to Check Cell Health
Nuvoton Technology is sampling the KA85010UA, a 26-cell battery monitoring IC that integrates electrochemical impedance spectroscopy (EIS). The device enables in-system battery degradation diagnosis, state-of-health (SOH) estimation, lifetime prediction and early detection of abnormal cell conditions without requiring external laboratory equipment.
Nuvoton KA85010UA battery monitoring IC with EIS
Nuvoton KA85010UA 26-cell battery monitoring IC with built-in EIS
Key Characteristics
  • Cell support: up to 26 cells
  • Core feature: integrated electrochemical impedance spectroscopy (EIS)
  • Measurement method: inductor-based EIS (uses two FETs + inductor)
  • Thermal advantage: reduces PCB temperature rise by approximately 93% compared with conventional resistor-based EIS methods
  • Supports battery degradation diagnosis and SOH estimation
  • Enables lifetime prediction and early detection of abnormalities
  • Measurements possible during battery operation, charging and rest
  • High correlation with dedicated EIS equipment and IEC 62620 AC internal-resistance method
  • Validated in joint research with AIST Group (results published in IEEE paper)
The inductor-based approach circulates energy stored in an inductor to generate the alternating measurement current, avoiding the significant heat generated when high currents are passed through a resistor. Evaluation examples include a 72 V pack with 1.5 A superimposed current and a 60 V pack with 0.7 A.
Target Applications
  • Automotive battery packs
  • Energy storage systems (ESS)
  • Battery management systems requiring advanced cell health diagnostics
By embedding EIS capability directly into the monitoring IC, the KA85010UA allows continuous, in-system assessment of cell health without the need for specialized external instruments.
Source: Electronics For You
