Renesas RX74M/RX74N 600MHz MCUs with MRAM for Industrial Automation
2 weeks ago
Renesas RX74M and RX74N 32-bit MCUs for Smart Industrial Devices
Renesas Electronics has launched the RX74M and RX74N — flagship 32-bit microcontrollers built on a 22 nm process and featuring embedded MRAM. Operating at up to 600 MHz, they deliver more than twice the performance of the previous RX72M/RX72N generation (240 MHz) and are designed for high-performance industrial and factory automation systems.
Renesas RX74M and RX74N microcontrollers
Renesas RX74M and RX74N 32-bit MCUs with MRAM
Key Characteristics
  • Core: RXv3e at up to 600 MHz
  • Process technology: 22 nm (first RX family on this node)
  • Memory:
    • 1 MB embedded MRAM
    • 256 KB zero-wait-state tightly coupled memory (TCM)
    • 1.5 MB SRAM
  • Performance: more than 2× that of RX72M/RX72N
  • MRAM advantage: write without prior erase → faster code/data updates and reduced system downtime
  • RX74M networking (single-chip):
    • EtherCAT slave controller
    • TSN-capable Gigabit Ethernet switch
    • CAN FD
    • Support for EtherCAT, PROFINET, EtherNet/IP
    • EtherNet/IP Device-Level Ring (DLR) redundancy
  • Security:
    • ProtectZone technology (secure / non-secure region separation)
    • Renesas Secure IP (RSIP) with enhanced public-key cryptography
    • Authenticated encryption and additional hash algorithms
    • Support for post-quantum cryptography (PQC) implementations
    • Designed to address Cyber Resilience Act (CRA) requirements
The combination of high clock speed, zero-wait TCM and MRAM enables consistent real-time performance even under frequent interrupts and branching, while the integrated industrial networking and hardware security features simplify IIoT connectivity and firmware protection.
Target Applications
  • RX74M: AC drives, industrial robots, PLCs, factory automation
  • RX74N: smart meters, power conditioners, HVAC systems
Source: Electronics For You
