1100 W Half-Brick PFC Module with 380 W/in³ Power Density
3 months ago
Advanced Energy Launches High-Power-Density 1100 W PFC Module in Half-Brick Form Factor
Advanced Energy has introduced the AIH03ZPFC, a board-mounted power factor correction (PFC) module that delivers 1100 W in a standard half-brick form factor. It is positioned as the industry’s first solution of this power level in such a compact package, combining high power density, high efficiency, and advanced digital features.
Advanced Energy AIH03ZPFC half-brick PFC module
Advanced Energy AIH03ZPFC — 1100 W PFC module in half-brick form factor
Key Specifications
  • Output power: 1100 W
  • Output voltage: Regulated non-isolated 390 VDC
  • Peak efficiency: up to 97.3% (2.3% higher than previous generation)
  • Power density: 380 W/in³ (44% increase vs prior designs)
  • Loss reduction: 46% lower losses compared to previous-generation PFCs
  • Form factor: Standard half-brick 2.4 × 2.3 in (61 × 58.4 mm), installed height 0.52 in (13.3 mm)
  • Cooling: Baseplate contact cooling
  • Operating temperature: –20 °C to +100 °C (startup from –40 °C)
  • Control: Digital PMBus interface with onboard monitoring
  • Additional features: Internal inrush current limiting, auxiliary power support
The module integrates functions that are rarely found in half-brick designs, allowing system designers to reduce overall size and complexity while improving efficiency and thermal performance.
Target Applications
  • High-density industrial power systems
  • Data center and high-performance computing power supplies
  • Medical and laboratory equipment
  • Telecom and networking infrastructure
  • Applications requiring compact AC-DC front-end conversion
By combining high power, high efficiency, and extensive integrated functionality in a standard half-brick package, the AIH03ZPFC enables denser and more efficient power architectures.
Source:  Electronics For You
